What is up with that?, unless you have two harddrives it's kind of slow.
And having all these folders that look nearly the
same makes my head spin.
A future ifoedit should have the option of keeping it to one folder
If I'm stripping a DVD, the resulting total files size will be smaller
and should be able to start writing over the older vobs as it goes.
You maybe need a 1GB temp file as a buffer, but I think it could
be done so maybe that is not needed either.
last time i looked, ifoedit DID have the option of copying vobs to a different folder. you're putting the new vobs into the same video_ts folder as the old ones arent you? simply copy them to a new folder and when you're finished rename it VIDEO_TS and burn it with nero. works fine for me.
Originally Posted by boss
Overwriting the original files is a bad idea. Disk I/O would not be substantially improved (unless the original file and new file were on opposite sides of the disk).
But what happens if you cancel IFOEDIT? Or if it (or your computer) crashes? You will be left with a mess of files that won't be good for anything. Then you would have to rip the original DVD again and start over. -
before you start stripping the vobs, you are giving the option to name the file to which they will be written. all the newly stripped vobs are placed in this file. end of story.
Can you mount an .ISO image to a hard drive , then copy the VIDEO_TS folder
By Bansaw in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2011, 18:11 -
Duplicate a DVD....can you simply copy Audio_TS folder and Video_TS folders
By True Colors in forum Authoring (DVD)Replies: 6Last Post: 29th Apr 2010, 14:37 -
Ifoedit, vobs have to be not less than a 1gb?
By Remyisme in forum Newbie / General discussionsReplies: 4Last Post: 25th Oct 2008, 05:12 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 10:39 -
Can't Toast VIDEO_TS ( not copy protected)
By rotuts in forum MacReplies: 3Last Post: 21st Jun 2007, 14:28
