I have a bin and cue that contain an SVCD MPG in
MODE 2/2336.
I can't extract the mpeg with CDmage like I usually do because the format isn't compatible (MODE 2/2336). I read up and found ISOBuster which performs the extraction. Now I can play the extracted SVCD mpegs just fine.
Now when I go to use TMPGenc to multiplex the SVCD->VCD. It gives me an illegal video stream message when I try to open up the mpg. I checked the mpg with mpgprop and it said there was an error in the audio packet header.
I tried to fix the mpg's with mpgcorrector (a shot in the dark i guess). I get the same error when I try to open with TMPGenc. Now I'm stuck. What should I do next?
Thanks for the help
steve
Results 1 to 1 of 1
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
SVCD 704x480 mpg stills with audio?
By jungle5150 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 29th Jul 2008, 16:28 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47
