  1. Is there a mpeg2 codec for windows media player which plays SVCD in the correct 4:3 ratio instead of a squashed little square in the middle???
  2. What?, if the file is only 480x480 is is only gone use 480 pixels.
    You can right click on the "small little square" and select 200%
    Or you can select full screen.
    Playing around with "keep aspect ratio" and
    adjust the window size to be 4:3 should help.
    PowerDVD or Zoomplayer have more options.
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    sjp2k -its not the codec that does that function but the player ..
    use windvd or powerdvd instead of media player ..
  4. So I'm guessing theres no way to do this in WMP?
    Nov 2001
    Sweet Home Alabama USA
    The elecard MPEG2 codec listed here is the one to use to let WMP recognise DAR(display aspect ratio) flags. I do however highly recommend a software player like PowereDVD instead.
    http://www.vcdhelp.com/tools.htm#codecs
  6. Yes, Unless you want problems don't install ELECARD MPEG2 decoder.
  7. Ditto on using PowerDVD,but if you purchase any Ulead product an mp2
    codec is auto.installed.
