I have a bin and cue that contain an MPG in
MODE 2/2336.
I can't extract the mpeg with CDmage like I usually do because the format isn't compatible (MODE 2/2336). I read up and found ISOBuster which performs the extraction. Now I can play the extracted SVCD mpegs just fine.
Now when I go to use TMPGenc to multiplex the SVCD->VCD. It gives me an illegal video stream message when I try to open up the mpg. I checked the mpg with mpgprop and it said there was an error in the audio packet header.
I tried to fix the mpg's with mpgcorrector (a shot in the dark i guess). I get the same error when I try to open with TMPGenc. Now I'm stuck. What should I do next?
Thanks for the help
steve
Results 1 to 1 of 1
How do I multiplex to FLV?
By Videogamer555 in forum Video ConversionReplies: 5Last Post: 30th Aug 2011, 04:26 -
Trick PSP video
By jntaylor63 in forum Video ConversionReplies: 0Last Post: 4th Aug 2011, 10:42 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 09:36 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
demultiplex and multiplex ..........HELP!
By efiste2 in forum DVD RippingReplies: 1Last Post: 21st Jul 2007, 18:01
