Hi,
I just want to know the differences between these two formats:
1 - Legacy compatible Format (MPEGAV, ENTRYSVD)
2 - SVCD Standard Compilant Format (MPEG2, ENTRYVCD)
Both are in the "Make Disk" menu in Ulead DVD Workshop but there are no referencies in the manual or help guide.
Thanks for all,
Unless you have problems using the "SVCD Standard compliant format", use it as your default.
The default after install is Legacy SVCD compatible format, but few players require this for compatiblity.
Some standalone players require the Legacy option. Future ones should not. When all else fails, test it out
Whovian
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 09:25 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 22:05 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 02:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 02:55
