I am making a new computer, the only thing i am confused about is what capture card i should get. I already have one, it cost me about aus$90, but some ppl say a cheap capture card will make the capture blocky. Also, the graphics card, i am thinking of gettin a geforce mx2 line out?? i dunno but it sounds ok. Does either make a difference? should i spend aus$450 on a line in/out card or keep my existing capture card and just buy a good graphics card for editing footage etc?
thanks
Results 1 to 1 of 1
Does a Motherboard's Chipset Make a Difference?
By wulf109 in forum ComputerReplies: 1Last Post: 20th Oct 2011, 10:43 -
Question about difference between direct capture and sound card recording
By jimdagys in forum AudioReplies: 3Last Post: 16th Sep 2009, 09:09 -
Does 4K really make a difference? Sony compares SD to 2K to 4K in PDF.
By edDV in forum Media Center PC / MediaCentersReplies: 3Last Post: 28th Dec 2008, 19:21 -
Does SATA make big difference for DVD burner?
By sdsumike619 in forum ComputerReplies: 6Last Post: 28th Nov 2008, 19:21 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
