vdub, cce, 23.9-25 fps, some resizing, textsub divx->svcd
My dvd player simply doesn't jump to time instead it says, "not an available option"
Some other movies ( svcd ) I got from sites work fine, they jump an all, but the ones I encode simply refuse.[/b]
It might depend on several factors.
1) Some DVD players only allow time search of NON-PBC discs, so make sure to disable PBC in your authoring software.
2) For time search to work properly the MPG must be muxed with scan offsets. bbMPEG does these 100% to spec, TMPGenc is close, but does not align it's packets so it might cause this effect.
3) Something else all together. -
Thanks snowmoon for the reply
But1.: I'm using nero 5.5.7.2, and VCD easy. As far As I know theese do PBC, without the possibility of disabling it.
And I've burnt movies in my burner, that work fine on my standalone
2, I'm using bbMpeg, and cce. So that couldn't be a problem, could it?
3, I'm still open to suggestions
Anyway, thanks for the help -
The second page of options under (s)vcd has a checkbox.
Use playback control.
Uncheck this option and the disk will be PBC free.
Sony Vegas - Time freeze doesn't work
By Reiden in forum EditingReplies: 0Last Post: 5th Feb 2012, 13:11 -
Why doesn't my imgburn program work this time?
By vladorlok in forum DVD RippingReplies: 19Last Post: 14th May 2010, 20:25 -
Converting Divx-AVI to MP4 - Output size option doesn't work
By tomzero in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2010, 07:30 -
DivX created by ffmpegX doesn't work on player?
By ambrosechapel in forum ffmpegX general discussionReplies: 7Last Post: 17th Oct 2008, 07:13 -
Any other options for mkv to vob? Mkv2vob doesn't work 100% of the time
By AndyD in forum Video ConversionReplies: 6Last Post: 12th Mar 2008, 18:13
