I was convertin [nm]RedDragon.ts.avi with Vdub, and it stopped, sayin
An unknown error occured (may be corrupt data). Error Code - 100.
I did a search in the forum for the same problem and someone had the same prob, someone replied to tell them to use the "scan video stream for errors" but no further instructions, so if someone knows the next step to fixing the problem, i'd be most grateful!
Download this version of Virtualdub (scroll down to the Mp3_Freeze version):
http://www.digital-digest.com/dvd/downloads/virtualdub.html
File > Open > Movie.avi > Video > Check For Video Freezes
After this process is doen (takes a while) a window will pop up and tell you how many and what number are bad frames.
Use this guide to help:
http://screw.wz.cz/avidef/AVIDeFreezer%20Tutorial.htm
You may also need this (although I don't personally use it)
http://www.divx-digest.com/software/avidefreezer.html"Today is only yesterdays tomorrow" -
Is it not easier to just choose "Direct stream" on both video and audio in Virtual Dub and save it to a new AVI file?
That is usually the first option....but it does'nt always work .Originally Posted by crack_man
Depends on the extent of the corruption."Today is only yesterdays tomorrow"
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 10:50 -
H264 in vdub giving me an error.
By SignedupGuest in forum Newbie / General discussionsReplies: 4Last Post: 1st Jul 2009, 09:23 -
FAVC error code
By drz400 in forum Authoring (DVD)Replies: 10Last Post: 10th Oct 2008, 16:18 -
Error: Sense key=Medium Error. Sense Code=0x73, 0x03.
By Idlewild in forum MacReplies: 14Last Post: 10th Mar 2008, 11:36 -
Vdub Mod Error with VOB conversion
By Aaron1927 in forum DVD RippingReplies: 3Last Post: 9th Aug 2007, 12:05
