Does anybody know whats wrong with the RED Dragon avi files currently available.
I've downloaded at least 4 copies know and they play witha blank screen and no sound however the timer moves along as if it's playing something.
I've tried it in DIVx players and Windows Media player.
Any help would be much appreciated.
Lee[/quote]
Closed Thread
Results 1 to 16 of 16
I'm pretty sure those are fake. There is alot of fakes you know, its been what less then 4 days its been in theaters give it sometime.
Here is the story, i've downloaded Men In Black 2, when i went in the folder file was called Mirority Reports after i opened player and played it its was Show Time.
I would suggest you use (assuming the video is an AVI) an AVI identifier. My favorite is GSpot, which gives you the most information. This will at least tell you whcih codec was used to encode the file, it may be something as simple as not having the right codecs. Gspot also will give you a list of what codecs are installed on your machine. Here's the link:
http://www.headbands.com/gspot/
(And no I'm NOT plugging like I've seen in some other posts recently
, it's just a cool app)
Then again, it could be fake
Prospero
Look for files that are not 102.00 long something like that anyways cos i downloaded it of kazaa works wkd
wkd film 2
injoy
I have Kazza and Overnet. Overnet worked the first time i tryed. Quite slow though so I used Kazza again. Went back to overnet and it doesn`t find anything or download anything. What have I done wrong or is there something you should do. PS does it have speed up like kazza for searching for other files to speed up yer download.
Do a websearch or try www.k-lite.tk and follow the links. Infact trym forgot its name Screener
weeyoo, dazsafc etc. I'm not going to explain what you already know
about the warez rule on this forum. If you continue to disregard I'll ask the admin to suspend both your nick AND your IP. The worst offender may get an abuse notification sent to his/her service provider.
CD media query...
By mjl1297 in forum MediaReplies: 4Last Post: 17th Nov 2010, 23:35 -
DVDStyler query...
By mjl1297 in forum Authoring (DVD)Replies: 0Last Post: 20th Jul 2010, 05:36 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
I need a genuis!!! Heavily red tinted or red hue.
By mikekrauser in forum Authoring (DVD)Replies: 4Last Post: 16th Aug 2009, 19:51 -
New Movie Release -- The Mummy: Tomb of the Dragon Emperor
By vhelp in forum Off topicReplies: 12Last Post: 25th Apr 2008, 11:55
Guys, have you really never heard of DC or DC++??? Those are the ultimate progs to use to download movies - i've used all those Kazaas and E-donkeys until i tried DC and DC++ 6 months ago and i will never go back.
