Hello, i downloaded a file called (Bridget.Jones.Diary.DVDRip.DiVX-ViTE) of kazaa and when i go 2 encode it plus i already have cut half the film i keep gettin a error message saying "-537403781 98656 and im using TMPGEnc why is this happing? can it b a bad avi file? cos this is really peein me off help would b nice
thanks in addvanced.
Was it "717,528 KB" ?
sig2dat:///|File:%20Bridget%20Jones's%20Diary(DVD-Rip%20-%20DivX).avi|Length:%20734748672%20Bytes,%20717528 KB|UUHash:%20=edfzyU70arHcGWMUKynUk933QH8=|
No I see its diffrent..
Don't cut it in half, use TMPGEnc to convert all of it, then cut the mpeg 1 in half with Merge&cut
However you should scan it for junk frames using Vdub, if there is anything wrong like VBR, your cut will cause a problem. -
The same file king john ill try that 1
cheers m8
Diary of a newbie FFmpeg learn to help others! convert to High quality!
By gugaoforums in forum Video ConversionReplies: 6Last Post: 10th Sep 2011, 03:07 -
My Travel Diary–2011 PowerDirector Video Contest
By sog328 in forum EditingReplies: 4Last Post: 13th Jul 2011, 18:03 -
Software to Record Voice/Audio. Diary!
By UmmAddan in forum AudioReplies: 4Last Post: 28th Jun 2008, 20:43 -
Indiana Jones and The Kingdom Of The Crystal Skull
By Epicurus8a in forum Off topicReplies: 53Last Post: 2nd Jun 2008, 17:19 -
Indiana Jones 4 title....
By j1d10t in forum Off topicReplies: 4Last Post: 10th Sep 2007, 18:54
