hi, i'm rather new to the vcd making scene. i've made a couple of mpgs into vcds using nero, but that's about it. recently i got a movie that has .vcd as the extention. i tried using nero to convert it and it burns, but my dvd player won't recognize it. i then changed the extention to .mpg but same thing happens. is .vcd even a valid extention? the file plays fine in wmp though so i don't know. . . what do you guys suggest?[/u]
First of all, don't use Nero to convert anything, its much better to use TMPGEnc.Originally Posted by CrispyYams
TMPGEnc can convert AVI,Mpeg to fully complaint VCD's by using one of the available PAL/NTSC VCD templates. You can then use that with Nero to make a VCD.
Where did you get the movie
was it ".mpg.vcd" or something ? if it is a mpeg 1 vcd the extension is usually .dat which can be loaded directly into any of the authoring programs without converting it to anything.
You could also load it into TMPGEnc > Mpeg tools > Merge&Cut > add > "MPEG 1 Video CD" from drop down > output path > name >start.
That would put it back as a .mpg
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 04:59 -
How to convert an .avi or .mkv or .mp4 file to mpgav for burning to a VCD
By jasoothai in forum Authoring (VCD/SVCD)Replies: 8Last Post: 29th Oct 2011, 20:35 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 11:25 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
