Hi,
I got my HP DVD200xi, I did my first production on DVD+RW using Sonic MyDVD. I was able to play it on my Pioneer DV 333. I tried burning the same movie on a DVD+R, using the same project from Sonic MyDVD and my player didn't want to read the disk at all. It just ejected it right away.
Same thing happened with a blank DVD+R.
I tried the same written DVD+R on a Pioneer 353 and the player said "I cannot play this disk".
I did not apply the patch for DVD+R media, patched supplied by Sonic.
Did any one have the same problem? I need an input from you guys before trying another blank disk.
I seem to remember having a similar problem with sonics dvdit. The easy solution wasd to burn to dvd+RW, test it, and if ok use nero (or something else) to copy the +rw to a +r disk (save times authoring twice anyway and allows you to test it without using a +r disk)
I was ready to do that and I don’t why I changed my mind and I left Sonic MyDVD to author again the same movie on DVD+R.
As I said, this happened without the patch provided be Sonic to correct DVD+R problems.
As in Canada a blank DVD+R is 10CDN$, I guess next time I won’t take any chance and I’ll author my movie using MyDVD and then copy the Video_TS folder to a DVD+R.
You mentioned copying the DVD+RW to a DVD+R. Is it any other way beside copying the Video_TS folder? -
To russwcj:
I followed your advice and by copying the VIDEO_TS folder with Nero 5.5.9 I could obtain a reliable DVD+R with the same video production.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
BD REbuilder ERRor - Error in attempt to extract audio/subs.
By ajhansen91 in forum Blu-ray RippingReplies: 1Last Post: 26th Mar 2009, 14:39 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
