  1. I wanted to watch tv with it like using the guid plus besides just doing capturing. but when I try to install the tv thing there is no listing for USA (they give you Afganastan but not USA lol.) so what do I do?
    *pardon my english, I dont take the time to type right.*
    ___insert witty, well writen, thoughtthrough comment here___
  2. I have the same problem with TV Wonder VE. No countries listed that use NTSC standard. I even downloaded the 7.6 beta version of ATI MMC thinking maybe it was just a bug from the non-ATI drivers I am using. No such luck. Still no NTSC countries. Anyone know a fix for this? I've cruised the ATI site a little and it seems to be a known problem without a fix so far.
  3. followed another link and found a fix!! Download and install the sourceforge drivers and when you install them make sure to pick ATI TV Wonder VE in the capture card dropdown, and also to pick the tuner (don't let it autodetect) For the card that we're talking sbout it is Phillips NTSC in the tuner dropdown click next or finish whatever it is to install the drivers. When it tells you it isn't tested for xp, ignore it and install anyway. Do a re-start and you should have all of the US and other NTSC areas. Worked for me, hope it helps!!
  4. Ok ill try it immediatly. I thank you very much.
