hi all
ive got a movie in rars ive unrared em using winACE i got some crc errors but the MPG was still there as 516megs (51m13s) when i play the mpg in windows media player all that plays is 9m12s....is there a way to repair the mpg????
thanks inadvance
nifty
Sort of...yes.
I suggest using TMPGEnc software or other MPEG encoder software (capable of reading .mpg files as source) to re-encode the .mpg file that you have. I have had many corrupt music video .mpg files before and the only way to "fix" them is to re-encode them to a new seperate file.
Also, you can use VCDEasy to read and analyze any .mpg file and show technical info about that file.
TMPGEnc website
http://www.tmpgenc.net
VCDEasy website
http://www.vcdeasy.org
Access to the path 'F:\.mpg' is denied. Any idea how to fix it??
By StangGurl in forum Authoring (DVD)Replies: 6Last Post: 17th Dec 2010, 19:29 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
Sound on both channel fix possible on mpg and wmv?
By Blå_Mocka in forum AudioReplies: 2Last Post: 3rd Jul 2008, 15:25 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
how to fix broken mpg file?
By ecc in forum Video ConversionReplies: 4Last Post: 6th Oct 2007, 08:56
