Ok i want to know if its possible.
This is what i have
This is what i want
I want to get rid of black stuff around frames, so i can reduce the size but keep the quality same.
Hey, those black bars are there for a reason: keep correct aspect ratio. Do you want the earth all streched up like an egg
Easy,
Get your output into MPEG2 format.
Hop into FLASK
go into the global edit , and hit preview.
start triming top n bottom till you get just what u want.
save out usign the codec flavour of your choice.
have a nice day. -
You can't crop the bars out without cropping the same amount from the sides otherwise you will lose aspect ratio. By cropping the sides you are going to lose close to %50 of your picture and if there is anything important on either the left or right side then it will be lost since you are not performing an actual pan and scan conversion.
If you really want to do this just use the crop function in your encoder, just about every encoder has this. In TMPGenc it is the clip frame filter.
Other than that the only way to remove the black bars without severely disturbing or distorting your picture is to play it back on a widescreen tv. -
Yes i thought about aspect ratio too, so i opened bunch of other widescreen movies in VirtualDub and it didn't have those bars all around. I'll try to do what you said.
Originally Posted by toretto
If you opened a DVD2AVI project (or something similar) from an anamorphic DVD those won't have as much black because a DVD player adds the letterboxing automatically for 4:3 TVs, and plays the movie as-is on 16:9 TVs.
Can someone explain how it's possible? 1080p at 1.17GB ?
By smackyourfupa in forum Newbie / General discussionsReplies: 4Last Post: 12th Feb 2011, 10:11 -
Can you explain this noise in XP ?
By Seeker47 in forum ComputerReplies: 20Last Post: 9th Oct 2010, 05:24 -
Explain a child domain?
By capman21 in forum ComputerReplies: 1Last Post: 30th Sep 2008, 23:41 -
Can somebody explain the problem with this dv footage.
By Aarzoo in forum RestorationReplies: 8Last Post: 18th Jul 2008, 09:28 -
can someone explain?
By icucmerc in forum Video ConversionReplies: 2Last Post: 4th Aug 2007, 10:57
