  1. I have a SVCD that I want to convert to mpg1. Now, TMPGEnc should be able to handle that easily, right? Just open the mpg (svcd) file and save as... and I do have mpg2 support left.
    That doesen't work however, no program will open my file. The only program I have some response from is WinDVD that can actually play it, so there's nothing wrong.
    When opening the file in Nero (trying to make a svcd cd of the mpg file), Nero says the file is 480x480 with a bitrate of 23,97 instead of 29,97 which is the standard. Is this the problem? If so, how do I fix it since no program I've tried can open it (tried TMPGEnc, FlaskMPG and MediaStudio 5.0)
    thanks for help
    Andreas
    You can use DVD2AVI. Click ON CONVERT HERE TO THE LEFT for a MPEG2,SVCD to MPEG1 guide.
