My capture program that come with card can only save in mpeg1 format and can not change resolution
Now i want to try other capture program
It is possible?
Try http://www.provideo.com.tw and look for the application of the pv-231 card. It should be compatible with your card.
BlackMagic Pro/Shuttle? First Capture Card.
By iDuskFang in forum Newbie / General discussionsReplies: 3Last Post: 7th Apr 2012, 17:28 -
Recommend a <$100 capture card for analog to lossless AVI codec
By Cheesyii in forum Capturing and VCRReplies: 8Last Post: 27th Dec 2011, 09:49 -
Need a program to capture VCR through Hauppagge card
By granturissimus in forum Capturing and VCRReplies: 7Last Post: 1st Feb 2011, 16:56 -
Who makes the best USB2 capture card for under $100?
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 7th May 2009, 17:52 -
I need a program to capture Pinnacle HDTV Pro Stick
By hpcampr in forum Capturing and VCRReplies: 8Last Post: 24th Jan 2008, 17:32
