When VCDEasy creates image files so that I can burn a SVCD with Toast on a Mac, it produces the proper image files along with the same number of "pregap" image files.
So, for a 2 sequence disk, VCDEasy gives me a bunch of files similar to this:
svcd01.img
pregap_svcd01.img
svcd02.img
pregap_svcd02.img
In alphabetical order the pregap image file comes *after* the actual image file for that sequence.
My question is this, when I go to burn a disk in Toast, should I reorder these files so that the pregap image comes *before* the image file for that sequence, or does it not matter?
I hope my explanation was clear.
Sean
Having only tried this method twice, common sense would lead me to believe that you are correct in assuming the pre-gap image files go before the svcd-track image files. However, I don't remember getting pre-gaps when I chunked my *.BIN file.
*Note: I did a comparative test between this method, and burning the (S)VCD while inside VPC, using Nero I believe. I found that the images aren't identical, and that there was some subtle problems (jerkiness, filepointer errors) that turned up using the Toast version. I also tried other disc image types in Toast (same sorce image file, same burner, same media, same burn speed), with worse results. Not sure if this method is truly ready for prime time.
Happy burning!
Burning AVI Files in Toast 7
By Luckyword in forum MacReplies: 9Last Post: 16th Jul 2010, 12:05 -
fixing bad sectors/Toast disk image
By danielmak in forum MacReplies: 6Last Post: 26th Jun 2008, 05:35 -
Toast 8 - Can I join 2 avi files to make one video?
By Ivor Bigone in forum MacReplies: 5Last Post: 13th Feb 2008, 09:32 -
Toast error message on .cue files
By Going gray in forum MacReplies: 8Last Post: 17th Aug 2007, 12:46 -
Making files for Toast 7
By MikeyGee1 in forum ffmpegX general discussionReplies: 7Last Post: 18th Jul 2007, 13:55
