  1. On my system, Nero doesn't actually truncate mpeg files, rather it shortens them by say 60 mb on a 450 mb mpeg-1 file.
    For years, I have used Nero 5.5.8.4 and earlier versions without problem. However, after upgrading to version 5.5.9.9 or after installing an incompatible program, Nero is now shortening both mpeg 1 and mpeg 2 files.
    When I drag and drop a mpeg, Nero reports a filesize shorter than the original - roughly 50 to 60 mbs for large mpeg 1 or 2 files. If I burn the image, the DAT file is indeed shorter and corrupt.
    I have reverted to previous versions of Nero (currently 5.5.80) after cleaning the registry and made sure the Nero Winaspi32.dll matches. The problem is consistent now across all versons.
    I use VCDEasy to create vcd/svcd images, and have no problems burning (well almost, see below). Fireburner, cdrwin, and diskjuggler run fine. Roxio EzCD was installed and removed. Using Adaptec ASPI32 4.60 (and no problems with 4.71 previously).
    There is a second possible (but highly implassible) issue with my burn of two movies recently downloaded from the net and imaged with VCDEasy. On the second cd of each movie, their is a 10 minute segment that is a repeat of a 10 minute segment on CD1. That is, cd2 has a ten minute segment overlayed (replaced) with a 10 minute segment from cd1. I believe the movies are corrupt, but others burning the same files say there is nothing wrong with the movies. I simply mention it because isn't 10 minutes the same as about 60 mb?
    Anyway, its a perplexing problem.
    Thanks.
  2. Well, I found my second problem. When watching two svcd's (or vcd's) back to back - in this case two cds for one movie - on my Hollywood Plus mpeg card, I get this weird problem where I see a repeat of a ten minute segment from the first cd while watching the second. I mean, I can scrub the time slider back and forth and there it is. If it happens again, I want to find out where this segment is being cached (disk or memory). There was nothing wrong with the movies. Thats what I get for being too cheap to buy a decent decoder card.
    Still, if anyone can help with the Nero truncate problem, I would appreciate it. I went back to the v4.71 adaptec apsi32 drivers, and got rid of cdr4_2k.sys (roxio leftover or from Mediaplayer burn plugin) and cdralw2k.sys. Looks like a long series of uninstalls coming up.
  3. Here is some info on what Nero sees and what other programs report. Mpeg-1 file is good, but Nero is dropping about 54 mb of data. Although Virtual dub is reporting 74mb of audio data, do you think this could be an audio problem. Thanks
    Nero:
    File Browser: 472,899,140 (451,815K)
    Video 1: 416,860,160 (407,090 KB)
    Duration: 45:12:35
    Pause: 00:05:00
    Size 352 x 240
    File: Info : Video CD
    Size: 408,619KB (418,426,753)
    File Browser - File Info = 54,472,387 (53,195 K)
    File Browser - Video 1: = 56,038,980 (54,725 K)
    Nero Write simulation:
    456 mb
    45:33:07
    Virtual Dub 1.4.10
    Video track
    Frame size, fps (Us per frame)
    352 x 240, 29.970 fps (33367 us)
    # of frames, time: 81305 (45:12)
    Number I, P, B frames
    4665, 22760, 53880
    I-frame min/avg/max total frame size
    1252, 22423, 28893 (102156K)
    P-frame min/avg/max total frame size
    315, 7497, 43181 (166647K)
    B-frame min/avg/max total frame size
    30, 2121, 9878 (111623K)
    Average Bitrate: 1149 Kbps (141KB/s)
    Audio Track
    Format: 44KHz stero, 224Kbps layer II
    # of frames: 103852
    Total Size 74181K (75,961,344)
    //** some calculations
    I+P+B =380,426K (389,556,224)
    I+P+B+Audio = 454,607K (465,517,568)
    M2-Edit Pro
    ==Panel | info | info | Mpeg Editor==
    E:\cdtemp\tosh&mats-ep11.mpg
    File name : E:\cdtemp\tosh&mats-ep11.mpg
    File size : 472899140
    Duration : 2712.8767s
    Number of frames: 81304
    Drop frame flag : not set
    Systems :
    format = MPEG-1 Systems
    Stream mux rate = 1411200
    b/s real bit rate = 1394531
    b/sVideo :
    stream ID = 0xE0
    format = MPEG-1
    chroma format = 4:2:0
    horizontal size = 352
    vertical size = 240
    aspect ratio = 1.0950 CCIR601 525
    line display width = 352
    display height = 240
    frame rate = 29.97
    frame/s bit rate = 1150000 bit/s
    start time code = 00:00:00:00
    first PTS = 0.3746889
    last PTS = 2713.218
    vbv buf size = 40960
    Audio :
    stream ID = 0xC0
    format = LayerII
    bit rate = 224000 bit/s
    sampling rate = 44100 Hz
    mode = stereo
    ID = 1
    last PTS = 2713.217
    audio duration = 2712.8687
    Filter Graph :
    "Default DirectSound Device"{79376820-07D0-11CF-A24D-0020AFD79767}
    "Video Renderer"{70E102B0-5556-11CE-97C0-00AA0055595A}
    "MPEG Audio Decoder"{4A2286E0-7BEF-11CE-9BD9-0000E202599C}
    "MPEG Video Decoder"{FEB50740-7BEF-11CE-9BD9-0000E202599C}
    "MPEG-I Stream Splitter"{336475D0-942A-11CE-A870-00AA002FEAB5}
    "E:\cdtemp\tosh&mats-ep11.mpg"{E436EBB5-524F-11CE-9F53-0020AF0BA770}
    == Sequence ==
    Frame 0
    0- -1 : 4681 SEQ 352 x 240 (progressive)
    pxl asp ratio= 1.0950 CCIR601 525 line
    frame rate = 29.970 frames/s
    bit rate = 1150000 b/s
    min buf size = 40960 bytes
    constrained = true
    IQ matrix = false
    non-IQ matrix = false
    == GOP ==
    Frame 0
    0- 15 : 4693 GOP 00:00:00:00 closed=true broken=false
    0 : 4701 PIC 0 I
    3 : 5953 PIC 3 P
    1 : 11458 PIC 1 B
    2 : 16345 PIC 2 B
    6 : 21201 PIC 6 P
    4 : 26058 PIC 4 B
    5 : 30914 PIC 5 B
    9 : 35771 PIC 9 P
    7 : 40627 PIC 7 B
    8 : 45484 PIC 8 B
    12 : 50340 PIC 12 P
    10 : 62168 PIC 10 B
    11 : 73997 PIC 11 B
    15 : 78853 PIC 15 P
    13 : 86064 PIC 13 B
    14 : 90920 PIC 14 B
    ==Picture==
    Frame 0
    0 : 4701 PIC 0 I
    vbv_delay = 22394
    ==Tools | DR. M | Examine==
    Examination for E:\cdtemp\tosh&mats-ep11.mpg
    Looking for missing or duplicate frames
    and for incorrect GOP and sequence headers.
    Verifying timestamping and TimeCode values in GOPs.
    Checking that the mux rate and bit rate are within 10%
    of claimed mux rate and bit rate respectively.
    Looking for non-mpeg bytes before the first startcode
    and after the last startcode.
    Verifying that the MPEG starts with a Sequence Start,
    and ends with a Sequence end.
    * Incorrect GOP timecode. Expected 00:02:03:09 but got 00:02:03:08
    * Incorrect GOP timecode. Expected 00:08:18:10 but got 00:08:18:09
    * Incorrect GOP timecode. Expected 00:09:17:21 but got 00:09:17:20
    * Incorrect GOP timecode. Expected 00:19:47:13 but got 00:19:47:12
    * Incorrect GOP timecode. Expected 00:25:32:21 but got 00:25:32:20
    * Incorrect GOP timecode. Expected 00:32:36:15 but got 00:32:36:14
    * Incorrect GOP timecode. Expected 00:41:48:16 but got 00:41:48:15
    Tpmg 2.57.41.146
    core 1.90.138
    MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 128kbps
    Premiere 6.5
    File Path: E:\cdtemp\tosh&mats-ep11.mpg
    File Size: 450.99MB bytes
    Total Duration: 0:45:10:02
    Average Data Rate: 170.23KB per second
    Image Size: 352 x 240
    Pixel Depth: 0 bits
    Frame Rate: 29.97 fps
    Audio: 44100 Hz - 16 bit - Stereo
    Montreal, Quebec, Canada
    I have no idea why Nero is truncating your files or why you are getting 10 minute segments repeated. I can't help but think that these problems are somehow related and need to be solved. I just wanted to suggest a possible work around for the Nero problem.
    If you have daemon tools installed, it creates a virtual cdrom drive that you can load a disk image to and then just use Nero to make a simple disk copy.
    So the steps are:
    1 - get and install: http://www.daemon-tools.com/daemon_tools.htm
    2- right click on the new tray icon, and select Virtual CD/DVD-ROM>Device...>Mount Image
    3- Point to your cue file
    4- Open Nero and do a disk copy from the new virtual drive to your CD burner
    Morloc
  5. Thank you for your reply.
    Typically, my workflow is to take a mpg and drop it into Nero or VCDEasy to create and burn a VCD or SVCD. I believe the situation you describe has more to do with DVD ripping to a bin/cue.
    Right now, there is no problem with creating a bin/cue with VCDEasy and burning it with some other program. My problem is just when I drag and drop a mpg into Nero, then Nero reports the imported mpeg at rough 10 to 11% less than its correct size.
    I've bee all over this, check to see which DLL's and registry entries used by various programs including Nero - nothing seems admiss. Howerver, Nero uses DirectSound, so thats my next area to explore.
    I will check out daemon-tools in due course. Thanks again.
