Hi ,ive been trying to copy some vcd,s to vhs(for my poor mates).PAL disks work fine but those from a NTSC source shake.Is there any simple way round this,or do i have to make it PAL format to start with]
Thanks in advance.
You could use TMPGenc to change the framerate and picture size to PAL standards. It's not a real frame rate conversion, though which is much more complicated. The result could have some jerkiness in scenes with lots of movement, but when you tape it to VHS it should be almost unnoticeable. Take a look at the guides provided on this site.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 20:42 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
NTSC VHS to NTSC DVD
By alir77 in forum RestorationReplies: 8Last Post: 8th Jan 2011, 05:32 -
AVI-file shakes after VirtualDub
By Kirill in forum Newbie / General discussionsReplies: 0Last Post: 22nd Aug 2010, 09:56
