Converted DV AVI to 'DVD-quality' MPEG with Pinnacle Studio 7. Conversion parameters were 6000 kbits/sec, 48000kHz audio, 720x480.
When I try to open in TMPGEnc, I get the "..can not open file or file format not supported.." error message.
Is this because of the high kbits/sec? Bug with Pinnacle? Is there a setting that can be changed/adjusted so TMPGEnc will open this file?
Thanks in advance....
TMPG will not accept mpeg-2 as input, unless you want to cut, mux etc. You can frameserve from DVD2AVI following the procedure in the guide to convert SVCD to VCD.
Everything I'm reading elsewhere is saying don't use Pinnacle's mpeg convertor at all as TMPGEnc is better. Capture to avi with Pinnacle & convert it to mpeg with TMPGEnc.
DVD plays, won't rip (now rips with CDRoller, won't import to TMPGEnc)
By koberulz in forum DVD RippingReplies: 14Last Post: 4th Dec 2011, 10:42 -
Software for S-video output on Pinnacle DC10 plus card(XP)
By Eightbitgnosis in forum Software PlayingReplies: 2Last Post: 30th Jan 2010, 10:33 -
Video output won't keep aspect ratio on a TV
By Skarett in forum Newbie / General discussionsReplies: 15Last Post: 28th Apr 2008, 07:40 -
Pinnacle won't make my files
By sapo198peru in forum DVD RippingReplies: 2Last Post: 20th Feb 2008, 02:19 -
DVD won't read...won't create avi thumbnails
By ru5ty in forum DVD & Blu-ray WritersReplies: 6Last Post: 27th Jul 2007, 21:04
