Results 1 to 13 of 13
  1. Did I read somewhere that it is possible to get 120mins on one cd?
    Apr 2002
    The State of Frustration
    Here is the guide for putting one movie on one CD:
    Guide
    Hello.
  3. Thank you. It is not a DVD rip but a downloaded movie file. Will it work for an SVCD too?
    Apr 2002
    Yes, skip the part about ripping and go to the TMPGEnc part. You will input your video file the same way.
    Hello.
  5. thanks. Have you any tips on how to make an SVCD easily. I am having a bit of trouble burning them.
    Apr 2002
    Did you read the Newbie guides, along with the SVCD section. Using your templates is supposed to reduce your problems, so hang in there.
    Hello.
  7. I read the newbie guide and followed what it said but I am having a problem when it comes to burning it. It stops burning during the burn and I don't know why.
    Apr 2002
    You did not mention if you used the templates, and what program you are using for the burn.
    Hello.
  9. I did use the template for ntsc and then vcd easy
    Apr 2002
    And the VCD does not work or it does not finish burning?
    Hello.
  11. It doesn't finish burning
    Apr 2002
    The video itself, does it play all the way through?
    Hello.
  13. No it only plays for about 25mins
