o.k now that I have a MPEG video, I want to put it onto cdr so that I may play it on a regular DVD player. Does anyone know how to do that? Do I just copy the files to the disc or must I put it into specific folders, or must i convert it to something else??
Results 1 to 9 of 9
What Copying Software are you using. Whichever it is, select Video CD and drog and drop the Mpeg to copy. It does something so it will play in your DVD player and thats it.
In Nero use the Wizard. Select compile a New CD, Then Other Formats, Then Video CD. Then Drap and Drop the File To burn.
Having an MPEG is one thing. Playing it on your DVD is another. First make sure your DVD player can play CD-R(W)s. Not VCDs, CD-Rs.
Next, you need to format your MPEG file to be burned properly. Some use TMPGEnc, others use NERO. I tried NERO, and I find it problematic, others swear by it.
Next, you author, or burn your MPEG file to your disk. Some programs can do the last two steps at once.
But remember, all this is academic if your DVD cannot play CD-Rs. So check that first.Hello. -
I thought all Mpeg Files were Video Standard. I thought TMPGenc was used just for converting AVI files to Mpegs.
Wrong - not all MPEGs are Video CD or any other standard - they can have different sizes, encoding, etc. etc. etc.
Look on this site under VCD and SVCD - they use MPEGs with very specific standards. There is a little leeway in SVCD. Anything else and it might or won't play on a VCD/SVCD capabile DVD player. Some DVD players are somewhat forgiving like some APEX models. SOme will play DVD only. Look under the players list for what yours may do.Panasonic DMR-ES45VS, keep those discs a burnin' -
ShadowRider, you evidently have not read ANY of the informational posts to the left. You are missing a lot of important information.
sorry, I haven't got a chance to read the posts until now because I had school, thanks alot for the help, I pretty much figured it out now, once agian thanks
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
What is the best freeware player to play ISO images, mpeg, flv, etc
By avz10 in forum Software PlayingReplies: 0Last Post: 27th Jun 2010, 14:16 -
DVD will play on new DVD player, but won't play on old
By joe8915 in forum Video ConversionReplies: 9Last Post: 18th Feb 2008, 18:57
