I have a rather large HD, but I still don't have enough space to keep a bunch of MPEG-2s laying around. Is converting them to DivX a good alternative? Is the quality as good?
Results 1 to 11 of 11
I would say keep your MPEG-2. If you want HD space, why not store them on CD-Rs?
Hello. -
I would not keep two Gigs tied up on my hard drive for just a movie. I would cut that puppy into three parts, store it on three CD-Rs until I am ready to burn it on an DVD-R. LOL that.
Hello. -
I don't wanna use CDRs. I guess I'll try converting to DivX 5 with Vidomi tonight. Unless there's a better program?
I use Gordian Knot which includes a bunch of programs all in one to make it very easy. It works best with movie length video. You open the mpeg2 movie in DVD2AVI - Save as D2v project - Open project in Gordian Knot - tell Gknot what output resolution and what size you want (ie 700 MB) and what codec to use (usually divx3). It is available at Doom9.org
What I did when I had a bunch of dv movies occupying many Gb of space on my hard drive, I just used Winzip to split them into 700mb parts so I could store them onto cd. This would take considerably less time than converting to divx and you would keep the original. But if you’re like me, you have to have a copy on your hard drive at all times.
So whatever floats your boat.I will not eat oysters. I want my food dead - not sick, not wounded - dead.- Woody Allen
fonoop.com -
I strongly suggest Xmpeg 4.5 2 pass vbr to Divx 5.02. It accepts mpeg2 source files and keeps it in the YUV colorspace for fast compression. Check out www.doom9.org for a guide. Divx is the best current codec for high quality high compression and keeping everything in YUV saves the time loss going from YUV to RGB and then back to YUV. H.264 will be the codec of the future but for now Divx 5.02 is the choice.
It seems he knew the answer already, laughed at a suggestion (which would be his best choice), then just likes to post about it.
Putting them onto CD-Rs or DVD-Rs is your best choice, unless you want to re-encode them again to MPG-2 after your Divx. Other wise you are stuck with watching them on your comp.
But it's your videos, your choice. -
um... When I tried to encode with Xmpeg, it gave a fatal error. "Unable to open log file" ???
Which Program Produces Better MPEG-4 AVC Quality Videos
By mohawkcr in forum Video ConversionReplies: 0Last Post: 1st Jul 2010, 14:10 -
Which format produces better quality overall MPEG-2, MPEG-4 or .x264?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2009, 03:00 -
what is the best program 4 capturing???i need one with good quality
By khalid81 in forum Capturing and VCRReplies: 1Last Post: 4th Aug 2009, 20:13 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
What program gives the best quality results, when converting AVI/DIVX/XVID
By Rockstar452 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 01:19
