Is there a way to make my sharp dv-700s be able to play (home)burned audio CD and VCD?
Thanks for replies.
Johan
Have you tested it yourself. If it doesn`t then It doesn`t I`m afraid. Almost all DVD players will play VCDs. But Some don`t play CDRs, some of the reasons can be with them being equipped with only 1 lazor. Maybe a Certain Brand of CDRs might play, but finding that brand might be like finding a needle in a haystack. Don`t go for what 1 person may have said. Test it for yourself. But like I said before, there probably won`t be anything you can do about it, to get it to play a CDR, as it will not be software in the player stopping it, just plain old Mechanics.
Sharp lc-40lb700x
By Margot in forum Newbie / General discussionsReplies: 0Last Post: 8th Jun 2010, 05:16 -
Sharp DV-RW370
By alduz in forum DVD & Blu-ray RecordersReplies: 0Last Post: 11th Mar 2010, 02:24 -
Sharp BD-HP20S does NOT play BD-R/BD-RE ???
By dre111nl in forum DVD & Blu-ray PlayersReplies: 9Last Post: 21st Mar 2009, 08:10 -
sharp dv-sv90
By tatusik in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Mar 2008, 11:02 -
Problem , sharp video ???
By ZaYoOoD in forum Software PlayingReplies: 1Last Post: 23rd Oct 2007, 10:32
