Can someone explain why cutting with TMPGenc should get more onto one cd.
uh, i didn't get that very well... I think you mean with WHY, HOW
Well, i generally use this trick, 35-40 Minits for SVCD and 59Minits for VCD
how?
start TMPG
FILE->MPEG TOOLS
MERGE & CUT
ADD YOUR FILE(mp(e)g)
doubleclick on it, this gives u a scroll bar, move to the minit you want it to split up, click on SET END FRAME
Press OK
RUN
Now, for snd part, you go to that exact frame, click on SET START frame, move X mins ahead and press END FRAME ->OK -> RUN
i hope you wanted to know this... otherwise, ask again and more clearly
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com
