I've got a xvid avi movie which I've managed to convert to mpeg to burn onto VCD.
I have altered the VFAPI settings in TMPGEnc (Ver 2.58) to achieve this.
The movie is fine except for a slight jerkiness which is only noticeable when the movie pans really.
Here are my settings -
Directshow Mult File reader 3
AVI2 (OpenDML) File reader 1
AVI VFW comp reader 0
Microsoft MPEG-1 Decoder 0
BMP/PPM/TGA/JPG File reader -2
Wave file reader -2
DVD2AVI Proj file reader 1.76 -2
TMPGEnc Proj File reader 2.58 -2
Can anyone suggest an improvement on these or a way to get rid of the jerkiness?
Does your chosen template match the framerate of the source?
Thanks banjazzer, you hit the nail on the head. I checked the AVi in Nandub and it has a framerate of 23.976 fps so I encoded at 24 fps instead of the usual 25 fps and bingo its fine!
Just needed a push in the right direction.
Thanks a lot
Encoding problems
By cdaters in forum ffmpegX general discussionReplies: 8Last Post: 2nd Feb 2010, 20:27 -
Encoding problems
By El Barto619 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2009, 23:32 -
Problems with Vimeo Encoding
By Xenon77 in forum Video Streaming DownloadingReplies: 2Last Post: 28th Apr 2009, 13:04 -
Problems encoding!
By villa99 in forum ffmpegX general discussionReplies: 4Last Post: 25th Mar 2009, 13:50 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 12:30
