When I try to load my (previously captured, or saved in Premiere) AVI's in VirtualDub, it refuses with the message:
"Couldn't locate decompressor for format 'DVSD' (unknown). VirtualDub requieres a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable."
So what do I do, install some codecs, or convert the AVI's to some other codec? I could do this with Premiere, but frame by frame, sloooooow!
Also, does using a VFW codec mean that I have a 2GB file size limit? My AVI's are > 4GB.
Before you do anything, locate a small free program called Canopus DV File Converter. This converts losslessy between various DV formats. One will almost certainly load into Virtualdub. 8)
Originally Posted by Tommyknocker
Joining AVI Files in VirtualDub.
By eliqush in forum EditingReplies: 12Last Post: 6th Jul 2009, 03:31 -
Cannot append some AVI files in VirtualDub.
By StehpenRH in forum EditingReplies: 3Last Post: 8th Oct 2008, 04:51 -
how do I compress multiple avi files with virtualdub?
By unloaded1 in forum Newbie / General discussionsReplies: 2Last Post: 1st Mar 2008, 23:43 -
Joining avi files with Virtualdub
By JaredKnight in forum EditingReplies: 10Last Post: 8th Jul 2007, 20:45 -
Join 18 .avi files with VirtualDub
By nlec in forum EditingReplies: 8Last Post: 16th Jun 2007, 00:32
