  1. Hi, I've got one of the new shiney-door DP G4s (867), and I'm fairly unimpressed with the rate I'm able to convert to mpg. Cleaner seems glacial, and toast/quicktime have been dodgy. Is there a better (and, especially, faster) way?
  2. thanks for the tip, I tried it and got a great mpeg video stream - but the audio didn't convert to vcd. What settings should I be using for audio with ffmpegX to create a VCD?
    thanks again!
  3. You should be using .MP2 audio for VCD. You can select one of the presets at the bottom to help you on your way.
