ok jus a lil question for u guys.
im using TMPGEnc and its pretty easy...but the question i have is how do i keep my video widescreen?
the avi file i have is widescreen but when i went to change it to mpeg it became fullscreen.
in aspect ratio what should i set it to, to maintain the widescreen format?
thanks alot
josh
PUT 4:3 for the source then under the advanced tab select full screen keep aspect ratio... use the preview button to see if it is what you want
im not quite sure i follow what yur saying.
there seems to be a few places that could influence widescreen or fullscreen.
the first looks like it would be expert setting for source and one of the subfields is aspect ratio, what should that be in order to get widescreen?
then there are the mpeg setting is there something in there that i need to change in order to keep the video file widescreen?
thanks alot
josh -
I would try 16:9 display under the advanced tab and 4:3 display under the video tab. Don't forget to use Full Screen(keep aspect ratio). These are the settings I use when I rip widescreen DVD's. Hope this can help you.
Digital movies from my video camera are 720x480.I save them as 720x480 dv avi.To author them for my widescreen tv i have both video and advanced tab set to 16:9,and they work out fine.Even old vcr tapes,i do the same and they have the right aspect ratio for my tv.
bmiller,ont.canada -
This is incorrect. Source aspect ratio is always 1:1(VGA) for avi. Video arrange method should be one of the *Full screen(keep aspect ratio)* options . This will show all the movie, and maintain aspect ratio.PUT 4:3 for the source then under the advanced tab select full screen keep aspect ratio... use the preview button to see if it is what you want
Under Video settings, aspect ratio is normally locked to 4:3. You can unlock this and use 16:9, although i find the standard setting fine on my widescreen TV. I just use the zoom function on the TV to suit my taste, and they also play fine on a standard TV.
DVD with 16:9 aspect ratio truncated on Vizio widescreen TV
By gschmidt in forum Authoring (DVD)Replies: 14Last Post: 29th Oct 2011, 17:48 -
Aspect ratio for SD Widescreen on YouTube
By matthewjohn23 in forum Video ConversionReplies: 9Last Post: 1st Nov 2010, 18:14 -
Converting from Mini DV - Problem with Aspect Ratio PAL Widescreen
By Videonisse in forum Capturing and VCRReplies: 9Last Post: 30th Jun 2009, 17:01 -
How would I combine these avis into widescreen or TV aspect ratio?
By Han Solo1 in forum Newbie / General discussionsReplies: 9Last Post: 6th Mar 2009, 16:48 -
Watching AVIs in normal aspect ratio on a widescreen TV
By fiiido in forum Newbie / General discussionsReplies: 6Last Post: 9th Aug 2007, 07:05
