I have downloaded every possible codec I can find but still can not get divx movies to play in neither the divx alpha player nor ms media player. Actually I can see the seek bar moving and timer, so the video is playing, I just have NO picture or Audio. Any suggestions please???!!!!
Note: I even downloaded the 'gspot codec' detector. It says I have the correct codec installed. Help !!!!!!!!!!!
I assume its not just one bad movie and that you have tried more than one. I found a few blank fakes on KAZAA that looked ligit but were just a series of black frames at 2 fps.
As a starting point, try loading the movie into an editor program like virtualdub and see if you can get the specs (file,info), that should tell you the video and audio codec and try the preview option.There's not much to do but then I can't do much anyway. -
Thanks. Yes I have downloaded a couple movies off kaaza. I tried loading them into virtualdub. And neither work. It says I do not have the correct DX50 codec. I'm just gonna assume they are bad copies. Since I have had other divx stuff and they seem to work. It is beyond me why anyone wonder post bad files.
ac3 avi movies don't play back in 5.1 on divx dvd player
By funkyspaceman in forum AudioReplies: 10Last Post: 22nd Oct 2015, 17:01 -
MPG movies show shorter time then actual... help needed
By wolf_ast in forum ComputerReplies: 5Last Post: 30th Mar 2011, 21:52 -
Can the PS2 play divx avi movies?
By amjad_z4 in forum DVD & Blu-ray PlayersReplies: 30Last Post: 14th Jul 2010, 06:52 -
Divx (.avi) movies with 5 sec audio delay - can these be saved?
By Hank Kinsley in forum Newbie / General discussionsReplies: 2Last Post: 19th Nov 2008, 23:20 -
DivX file needed
By Tbag in forum ComputerReplies: 2Last Post: 25th Oct 2007, 17:35
