i have converted a divx-file to vcd with Nero.
I hear the sound but the picture is black.
Any help ?
If i try to do it with TMPGE , i get the errormessage : unsuported file
Have you tried to convert to VCD format with TMPGEnc's templates?
Hello. -
it is TMPGE that gives me the 'unsupported file'.
I have now installed latest cocecs and will try again -
And make sure the Direct Show is at the highest priority.
Hello. -
Maybe this will work
I use TMPGenc 12a (older version) and open the Divx in this program.
I convert it to a VCD (I use VCD-pal at a framerate of 25 fps). This done with the template (In the bottom click at load). After that you can use it as a "normal" VCD-file and can you burn it. The newer versions of TMPGenc don't support the DIXV-format -
Maybe the older version of TMPGEnc will work, but I take exception with the statement it does not work with DivX. I use it with DivX files all the time, normally and frameserving.
Hello.
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 01:06 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 16:41 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 07:41
