right im trying to get tmpgenc to take mpeg 2 files from a svcd so that i can convert a 3cd release of a film to 2cd's. Bu tthe problem is tmpgenc wont take the mpg file. It says invalid file type or something along those lines. I have power dvd installed and the latest version of tmpgenc plus installed! Any help much appreciated.
Results 1 to 9 of 9
And the Direct Show is set as the highest priority?
Hello. -
You need to have a handler for mpeg2 files in tmpg. It's called m2v_vfp-0.4.6.zip and I thought I found it here but looked again and I'm not sure e-mail me and I'll send it back if you want.
direct show is set as highest priority, i have downloaded the file m2v_vfp-0.4.6.zip and put that in the directory and still not happening.
Banjazzer when u said i will need to run it through DVD2AVI do you mean i will need to convert it to avi and then back to mpeg?
Anyway below is the error and the vfapi screenshot.
www.theforumisdown.com/uploadfiles/0802/vfapiplugin.jpg www.theforumisdown.com/uploadfiles/0802/tmpegencerror.jpg -
sorry banjazzer my aim is to join the 3 mpg files from the 3cd svcd release then split it in two so i have two files of an equal size the encode each of the two files with a less botrate so it will fit on 2 cd's
Then you first use TMPG's mpeg tools, Merge and cut (Type MPEG-2 Video-CD) to produce 2 mpegs. You can then do as I suggest with DVD2AVI to feed to TMPG to recode them at a lower bitrate. I would suggest going to VCD, because SVCD at low bitrate does not look too good, and you can get 80 minutes VCD per disc.
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 08:18 -
Womble or TMPGEnc MPEG Editor?
By Mike99 in forum EditingReplies: 14Last Post: 11th Aug 2008, 09:32 -
Mpeg-2 conversion with TMPGEnc: output too bright
By Novie in forum Video ConversionReplies: 10Last Post: 23rd Nov 2007, 10:31 -
TMPGEnc MPEG Editor 2.0 PREMIUM
By jaffacaique in forum EditingReplies: 0Last Post: 10th Oct 2007, 03:53 -
TMPGENC wont accept an mpeg :S
By chocolate_brownie in forum EditingReplies: 4Last Post: 7th Aug 2007, 17:34
