Hello
I am trying to follow the Step by Step for capturing into Virtual Dub, I am using VisionTek Ti4600 Video In, when I try to set the Video Format/Image Format I am unable to select YUY2 or RGB 24bit, all I get is UYVY
Does anyone have any idea why? ( I am assuming it has to do with the video capture drivers which are the nVidia WDM capture drivers 1.16 )
Thanx
"Computers are stupid, but they are capable of being stupid one million times per second"
Hi,
I get the same problem! I've got a MSI ti4200 and I use the Video In...
Can't select the custom format (Error 418...) and only UYVY as image format??
Why is this so??
I'm running the NVIDIA detonator 41.09 and the WDM drivers 1.08.. these should be the right ones.
PLZ Help -
same goes for me.
Can't pick anything else and I always get the damn Error 418.
Convert YUY2 to RGB
By jrivord in forum Video Streaming DownloadingReplies: 8Last Post: 19th Aug 2010, 11:21 -
YUY2 Codec for Quicktime?
By EZ-Fan in forum Software PlayingReplies: 1Last Post: 12th May 2009, 09:07 -
YUY2 Vs. UYVY Capture
By W_Eagle in forum Capturing and VCRReplies: 2Last Post: 11th Jul 2008, 11:15 -
TDK DVDR840G wont read anything after tryin to remove possible virus
By kemet in forum DVD & Blu-ray RecordersReplies: 9Last Post: 1st Feb 2008, 11:09 -
YUY2 or RGB for vhs capture?
By RH+ in forum Capturing and VCRReplies: 2Last Post: 3rd Nov 2007, 13:46
