I just got a Dell Dimension 4500 with a DVD player and 40x10x40x CD-RW with Easy CD Creator 5.2. Using Virtual Dub TMPGEnc and VCDEasy will I be able to burn a VCD? I already know how to do it but I was never able to because of my old hardware, but now I'm wondering if anyone has these Dell parts or knows if they work with VCDing.
....DUDE!
Guest
I'm not too sure about the VCDEasy working ok. I was never able to
get it to work on my system. CD Creator 5.2, is that the Platinum Edition?
The basic version does not have the VCD option. The Platinum does.
As far as everything else, looks great! Just to compare:
My home system= 500mhz AMD, 327ram. Encode time for a 1 hour
40 minute movie is 8.5 - 9.0 hours.
P4 running at 2.4 gig with 512ram. Encode time on the same movie
is 1 hr 15 minutes.
You should be plenty happy with your Dell.
Enjoy!! -
Thanks. Do you know of any VCD programs other than VCDEasy that would work well for me?
....DUDE! -
Try Nero thats what I've been using for months and I've never had it mess up on me.
GuestSo far this combo has never failed:Originally Posted by Cory-
VDub, TMPGEnc and Nero.
Goodluck! -
Nero is only really appropriate for simple multitrack VCDs. It's menuing system is both buggy and simple to a fault.
If you want more authoring options/flexibility, I strongly suggest you using VCDImager +/- a GUI (e.g., VCDEasy or TSCV).
There are some other commercial solutions (e.g., VideoPack5) that a pretty good too (though you will have to pay for it).
Regards.Michael Tam
w: Morsels of Evidence
11 Programmes used - still can't join mp4 successfully?
By The.King in forum EditingReplies: 20Last Post: 13th Oct 2012, 03:32 -
Can't get multiAVCHD to successfully create an AVCHD folder???
By jwmghf in forum Authoring (Blu-ray)Replies: 15Last Post: 17th Nov 2011, 13:37 -
Have you successfully backed up the Casino Royale?
By coody in forum DVD RippingReplies: 122Last Post: 27th Sep 2010, 03:21 -
Tin Man (from Universal HD) - anyone able to successfully convert to MKV?
By Tiernan in forum DVB / IPTVReplies: 6Last Post: 20th Mar 2010, 16:55 -
is there a way to burn using prime successfully
By ricanchriz in forum Newbie / General discussionsReplies: 3Last Post: 8th Feb 2008, 18:10
