  1. I have made video files and DVDit says there is no decoder found when i have been able to use it before. I reinstalled my OS (XP pro) and i can not make new DVDs now because it will not allow me to add in video that i know once worked anyone have a clue??
  2. Member ashtones's Avatar
    Aug 2001
    I have been having the same problem with a different twist. On mine it says the file appears to be neither NTSC or Pal. What else is there. LOL
  3. You did not mentioned how you made Videofiles.
    Did you try to re-encode with eg TmpGENc?
