    Aug 2002
    DK
    Hello !
    Does anyone know how to multiplex/join files of DivX ? I know how to do it with MPEG-files using TMPGEnc, but is there anything similar to this when it comes to DivX ?
    JIR
    Apr 2002
    The State of Frustration
    Sure. if the files are identical, you may use the Append Avi function in Virtual Dub. If not, you can use the AviSynth and modify the following script to join your files:
    AviSource("c:\video1.avi").BicubicResize(320,240)
    +AviSource("c:\video2.avi").BicubicResize(320,240)
    Keep in mind you can change te resolution as well if you wish.
    Also, you have to configure your system to use AviSynth, here
    Hello.
    Aug 2002
    DK
    Okay, thank's. It worked with VirtualDub.
