I have capture from vhs w/virtual dud, frame rate 29
but the picture is fuzzy what can i do to clean up real sharp w/ better colors
When you are ready to capture, select Video-->Filters-->Add. Select the Sharpen filter. Select configure. Although it will not make you capture perfect, it will increase its sharpness somewhat.
Also, select Video-->Source. This box allows you to configure saturation and hue for your colors, but can also alter brightness and contrast.Hello. -
No wonder. You need Virtualdub.I have capture from vhs w/virtual dud,
actually most filters should be applied post-cat, noy during cap. For color, go into video/source and try and find the analog adjustments for your card and boost saturation by about 5% or so. It helps to "chotochrome" the image and make it more pleasing in terms of colors. It also helps since mpeg compression often wahes out color.
I use the msharpen filter since it's less hars than the standard sharpen filter. All sharening filters in vdub need to be run on progressive images, so if you are capturing at 480 or greater lines then you need to use a viewfields before msharpen and an unviewfields before the end of your filter list.
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 02:06 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 05:52 -
how to enhance sound qaulity of dvd clips from security cameras
By sydneynewbie in forum Newbie / General discussionsReplies: 15Last Post: 4th Apr 2009, 06:36 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 21:00 -
Qaulity Capture Card for VHS-DVD & Computer TV Viewing/Capturing
By RubicksCube13 in forum Capturing and VCRReplies: 1Last Post: 11th Nov 2007, 09:00
