I have been using the very fine dvd2svcd for transfering divx files to dvdr using cce,however when i do it using vbr 2/3/4 pass it wont be accepted by dazzle dvd to aurthor it,i get an error that it is 9800 kbs and not within dvd standards and when i play the encoded file in one mp this confirms the data rate at 9800 i have even lowered the max rate in dvd2svcd from max9000 to 6000 with avr max at 4600 and still the same problem.when i use the cbr though it works fine and is within standards.I am using the non muxed mpeg with the separate mp2 file for dazzle and although one mp says the data rate of the muxed file is lower than 9800kbs (7474kbs) this also will not be accepted by dazzle.have tried dvditpe and get a warning there saying not within standards.. Anyone know why this is happening is this cce or the divx file .I have even run the mpeg through a bitrate veiwer and that shows that max bitrate does not exceed 7650kps..so unless anyone can help i will either have to use cbr or tmgenc......spaceman
Results 1 to 1 of 1
1GB AVI to DVD doesn't fit on DVDR?
By juggaloninjachoo in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2012, 13:32 -
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 12:35 -
copy avi file from scratched dvdr
By octeuron in forum Newbie / General discussionsReplies: 7Last Post: 10th Mar 2010, 01:14 -
AVI file(s) too large for DVDR
By sybarite in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2008, 20:35 -
Is This A Common Problem? DVDr to AVI
By innovyse in forum DVD RippingReplies: 1Last Post: 21st Jan 2008, 05:09
