This is just something I happened upon, no big deal really, but when copying a DAT from a VCD to my HDD in order to use a small clip from a movie (an old James Mason flick called "A Deadly Affair") in a cheesy short video, I discovered that Ulead Video Studio 6 can open the DAT without first actually converting to MPG (to get the header right) or even changing the file extension to MPG. I figured that it probably could, but I wasn't sure. In any event, it sure is a lot faster to open it on the CD, find the clip, trim the clip out then save that clip (re-mux it actually, no quality loss) than it is to copy the whole thing to your HDD.
Results 1 to 1 of 1
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 06:50 -
Recovering damaged dvd files FYI
By Starman* in forum Newbie / General discussionsReplies: 0Last Post: 3rd Apr 2008, 10:32 -
I have a .DAT file and don't know what program I need to open it
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2008, 15:42 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 06:54
