How can I capture in SVCD PAL format using Power VCR 3.0 since there are no predefined SVCD settings?
Custom settings do not support 480*576 resolution.
THNX.
Hi
I get better results results by making a custom profile.
DVD Pal
Bitrate 7500
High Quality 3
Then encoding to SVCD after using TMPGEnc.
Fozzee -
Powervcr keeps its profile information in the registry.
If you are comfortable with editing the registry just do a search on "PowerVCR" until you find all the defaults. Just insert the new size or sizes. Make just you use the exact format and spacing of the existing ones. Easy as pie. After this you will then be able to select 480x576 or whatever else you put in the registry within the program.
If you need more info, this information has been posted a few times before.
Do a search in the forum on Powervcr and all the posts will be listed. Just read until you find the one you want.There's not much to do but then I can't do much anyway. -
I found that registry hack, but it seems it is not working since there is no changes in selection of resolutions-they stayed as before.
I am running WIN XP PRO.
What am I doing wrong?
Power adapters for external capture cards
By pinetop in forum Capturing and VCRReplies: 0Last Post: 5th Mar 2011, 01:34 -
capture from vcr
By bbxrider in forum Capturing and VCRReplies: 27Last Post: 16th Aug 2009, 17:18 -
VCR capture troubleshoot
By Abas-Avara in forum Capturing and VCRReplies: 11Last Post: 16th Aug 2009, 05:26 -
capture video from VCR
By nbdeb59 in forum Capturing and VCRReplies: 2Last Post: 3rd Jul 2009, 00:57 -
Capture from VCR or Camera?
By thomasj in forum Capturing and VCRReplies: 3Last Post: 26th Nov 2008, 15:13
