Results 1 to 9 of 9
  1. I was thinking of buying a 100 pack. Has anyone had any problems with this media? I'm using a HP200i. thx
  2. me too.. but the DVD-R ones.. anyone? some ppl says its ok and its cheap too.. just wanna make sure..
    Dec 2001
    South of Sydney. Aus
    I'm in Australia & have tried the Ritek gold & have found them unreliable. I ordered 10 but received 20 (& was billed) in a spindle. Problably 20% have shown errors, with one disc with a smaller ID hole that would not fit on a generic holder, the disc surface was also marked.
  4. dilligaf said [I'm in Australia]
    I too am from Australia and am interested in where you obtain your media from. The cheapest I can find a dvd+r in Aus is $7.25AUD each for 100pack.
  5. hey aus ripper
    www.discshop.com.au
    laser 4.7gb 2x 4.50 each great quality!
    if ure in sydney every sunday at north rocks westfield s computer stalls 5.00 each minmum 100 from monica of nasatech technologies oik hope this helps!!
  6. You guys are just a bunch of thread hijackers
  7. Sorry Hex.
    It was just a good opportunity to catch up with other Aussies.
    davidc78 thanks for the site, but the $4.50 discs are -R not +R. but it looks like I can get +R for $6.20.
    Unfortunately I live in Wodonga. So I will have to miss the Sydney Markets.
  8. $7.50 each !!??...and people are hoping that DVD R+ wil catch on.. I think not... I buy DVD-R for £0.88 each and you can get Bulkpaq for £0.44 each , although they are a bit unreliable (although the new Generation 3 are better)
  9. I have used HP (7 disks), memorex (8 disks) and Ritek (15 disks) DVD +R. I can tell no difference. I have had no problems with any of above. Using a HP dvd 200i to burn with.
    I'm purchasing Ritek at present since they are cheaper $23 for 10 at RIMA
