Hi!
I successfully converted a wmv video (320x240, 25fps) to avi format using Graphedit. Using the avi, I tried to convert it to VCD (PAL) using VDub 1.4.10 frameserving to TMPGenc Plus 2.58, but the quality was very bad. Very blocky, details (eg. faces, objects) are distorted. I used the following settings:
VDub 1.4.10
temporal smoother (5)
compression : Huffyuv 2.1.1, Predict median/gradient best
TMPGenc Plus 2.58
Video arrange method - custom size at 320x240 (black borders to 352x288)
Noise reduction (50,1,50)
Sharpen (50,50)
Motion Search - Highest quality
Any suggestions to improve the quality?
Regards,
Chi8ng -
Personnally I think your TMPGEnc Noise Reduction is far too high... going higher than 20 is not really recommanded because it creates more noise than reducing it. When my picture is not too bad I use 8,1,8 and when the picture is not good you can higher 1 to 2,3 or 4 depending of your movie. Also don't forget to activate "Soften Block Noise" and "Use Floating Point DCT"...
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
bad quality on youtube
By stansvid in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2011, 21:57 -
Getting bad quality with AutoGK
By alc112 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Aug 2010, 09:37 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Bad quality downscaling...
By Emillister in forum Video ConversionReplies: 33Last Post: 29th Aug 2009, 13:48
