Hi, I don't think that I know what I'm doing here. But first I would like to know if there is a way to fit a 7GB video on a 700mb cdr?
The short answer would be no (most of the time). The size of a DVD in GB is not always directly proportional to the length of the movie, which is the limiting factor along with the aspect ratio of the movie.
I personally have just being able to put almost 60 minutes in a SVCD disc, and that was in 16:9 aspect ratio, as for VCD the most I have done is 90 minutes. Of course your mileage may vary according to each project and how picky your DVD player is. -
I am a newbie at this (so take anything I say with a block of salt) but I don't think you could compress 7gb down to 700mb without serious cropping and cutting the bit rate way down...
I will be curious to see what others say.
bigb -
No,no you can't chop it down from 7GB into 700mb. I was thinking about spliting it into two cdrs, how should i do that? And what would be the best format that i could use?
shouldn't go by the filesize of the DVD..
go by the movie length.....
usually, it's 2+ hours on 3 discs (crappy quality if u try to fit on 2 and "looks fine to me on TV" doesn't count)
Which camcorder (newbie question)
By CliveJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 19th Aug 2011, 12:36 -
Newbie codec question
By fotoruss in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 21:47 -
Newbie with a question on using Avidemux
By The Monarch in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 22:25 -
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 10:57 -
Newbie question about cd music
By justalice in forum AudioReplies: 4Last Post: 7th Apr 2008, 19:08
