cant open mpeg2 files in tmpeg to cut them in half for cd use, why not? what do i need?
What kind of error message are you getting, and how long have you had TMPGEnc?
Hello. -
ok i did get to open it under merge and cut and but im getting "stream read error" at the end but it seems to be okay. prooblem though i set it to end at like 50 even and it ends at like 50:01 in the movie like a minute off how come?
that is 1 frame - not 1 minute
time code is in hours : minutes : sec : frames
if it is : between sec and frames it is Non drop frame and if it is ; between sec and frames it is drop frame
it will move cut to closest I frame (more or less - tmpgenc cut is not exact) for editing which is normal in most mpeg editors .. -
i stand corrected -- i just checked tmpgenc editor and it doesnt show frames (i dont use it) though it does elsewhere in program .. so skip the frames part above ..
MVK to MPEG2 - TMPGEnc
By zecaloteiro in forum Video ConversionReplies: 1Last Post: 18th May 2010, 09:32 -
Mpeg2=>Mpeg1=>PowerPoint via TMPGEnc but weird DAR
By l-w-c in forum Video ConversionReplies: 1Last Post: 24th Jan 2010, 10:17 -
TMPGEnc problems with RMVB -> Mpeg2 conversion
By rebel316 in forum Video ConversionReplies: 2Last Post: 7th Aug 2007, 05:33 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 30th Jul 2007, 00:57 -
Blocky conversion DV-->Mpeg2 @ 9000Kbps using TMPGEnc 4.0
By kamaleon in forum Video ConversionReplies: 34Last Post: 15th Jul 2007, 18:25
