Can anyone answer a question regarding VCD playback/compatibility on a JVC DVD player? I have been using "Sefy's" guide to creating VCD's. The process has worked extremely smooth however, while I can play back my VCD files (MPEG-1 and MPEG-2) on my PC (ATI file player), I cannot do so on my DVD/VCD player. Is there a way around this through encoding or is it a hardware compatibility problem with my DVD player?
Have you checked the dvd players list for cd-r/cd-rw/vcd/svcd compatibilitty for you player?
You can also test to burn our vcd samples and see if they works. http://www.vcdhelp.com/vcd.htm#samples.htm -
Yes. Unfortunately, my JVC model cannot play DVD ROM/RAM/Audio/R/RW or CD R/RW/ROM. Essentially, it cannot play burnt material. Being new to video capture and creating video CD's, I did not factor this in when I purchased my unit. It is a great player otherwise. I'm simply trying to find a way around this dilemma before I think about buying a new unit. The database indicated a user was able to play audio on a Pacific Digital CDRW. If so, maybe there is some hope. Thanks for your help.
I forgot to mention that I purchased a VCD in Malaysia last year. Aside from the fair quality, my unit was able to play with no problem. I suspect that this VCD was a "copy" which again indicates to me that the JVC may be able to play certain types of burnt media.
JVC (GR-DVF21) DV in/out - not showing on DVD player ?
By Roamingdoc in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2011, 10:46 -
JVC XV-N480B DVD player won't play on NTSC television
By mike2021 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 7th Jun 2010, 23:39 -
JVC DVD player flashing, otherwise dead
By lboiv001 in forum Media Center PC / MediaCentersReplies: 0Last Post: 9th Dec 2009, 01:13 -
JVC SR-MV55US - Users with Experience with JVC Professional S-VHS/DVD Decks
By Anonymous4 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Aug 2008, 15:23 -
Upconversion DVD player w/ S/VCD
By Clessoulis in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Feb 2008, 09:43
