I saw a set of Imation CD labelling markers at COmpUSA, and I am wondering if anyone has used them or any other markers for labelling or writing on their CDs? Wouldn't the heat from the drive cause the ink to get within the drive?
THx
Sharpeis or other permenenet felt tip marker is all you need to write on cd-r and cd-rw's. No you don't get the ink inside the drive.
Another Sharpie user here.I wouldn't put any label on due to curling
or inbalance while playing -
I also used Sharpies and the TDK CD markers. You don't need any special marker to write on CDs and permanent marker should do. The only thing is make sure the marker is water base instead of oil base, and that the tip of the marker isn't too hard so you don't accidentally scratch the CD while writing.
-LeeBear -
Sharpies are not water based, though I sometimes use them and have had no problems. Dixon makes a water based marker.
Longevity of CDs and DVDs? Are my old CDs starting to lose it?
By garybeck in forum DVD & Blu-ray RecordersReplies: 15Last Post: 25th Jan 2013, 13:38 -
time marker in mov, or mpeq4?
By mias in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2010, 05:33 -
HELP! Too Much Text - I Need Labelling Template For Text
By kasius in forum MediaReplies: 5Last Post: 6th Dec 2008, 16:08 -
Best methods of labelling DVDR's, please.
By StuR in forum Authoring (DVD)Replies: 14Last Post: 24th Jan 2008, 12:07 -
Using ARROW/MARKER to pin point a figure in your video!
By godsownson in forum MacReplies: 5Last Post: 10th Dec 2007, 21:12
