i was converting a divx to 2 disk and it keeps coming out to big. i need a bitrate calculator for Constand Quality. is there one out there. or is there a way to figure it out
With CQ you have no way to tell what the final size will be. Just take a shot with a lower CQ or MAX bitrate or just use 2-pass with the average being what your bitrate calc spit out.
Usually it's more like 9 - 12 hours for me and the file is too small. Anyways, always do a test with a brightly lit or action scene for a duration of 1 - 2 minutes and check the file size at the end of the encode. You can then extrapolate to see what your final file size should be. If you use a dark scene or one with little movement, then the file sizes will appear to be smaller since these scenes use the lower bitrate settings. CQ is tricky to play with but looks great if done right...
a rough rule of thumb for CQ is:
CQ86-1hr
CQ82-1hr to 1hr15min
CQ78-1hr15min to 1hr30min
CQ74-1hr30min to 1hr45min
CQ70-1hr45min to 2hrs
Remember,this is very rough so it depends on the type of movie (action etc).....but its worked pretty good for me."Today is only yesterdays tomorrow" -
Thats on 1.
I personally never go below CQ78 because the deterioration in quality becomes evident to me below that point."Today is only yesterdays tomorrow"
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
My First Big Project to film about 20 hours of footage
By Intergage in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2010, 22:18 -
12gb avi file(7.5 hours) converted to multiple dvds?
By tritiqw in forum Newbie / General discussionsReplies: 4Last Post: 8th Jan 2010, 16:27 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 22:23 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40
