I was in another forum today and they were talking about how some TV Tuner card's can watch channels that are blocked out by the cable company by "cracking the channels"
do any of you guys know how to do this ? I would really like to know since I only have the Basic cable and would really like the other channels
Thanks for your Help
Results 1 to 18 of 18
hell yea !
if you find out - let me know I'll add it to my AIW Tool
I Want My Spice TV!
If your cable company is blocking channels by filtering the horizontal or vertical sync, a digital capture card might be able to lock-on to the signal and produce a picture. This type of filtering is usually done by the cable box in your home.
If your cable company is filtering channels by using a low pass filter or some other frequency specific filtering, then you are out of luck, as there is no video signal to lock on to. This type of filtering is usually done on the pole or tap outside your home.
Either and/or both types can be used, even within the same neighborhood.
RF
on my locked channels the video is blurry n their r lines goin up and down but the audio is crystal clear.
i can listen to them on my ati -
Done by the cable box ? I dont have a cable box but you say this is possable , at least with the one type so how would I go about filtering out the block or what ever it is that they use to block this out I.E My parents called the cable company to block out MTV , I still get the channel but it is all screwy looking so is it possable to fix this ?
Thanks for your help -
ur parents blocked mtv.
why.
their's nothing wrong with that channel.
why.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
because MTV is EVIL!!! -
I have no Idea why but any howz looks like nobody knows how to do this so maybe its really not possable
Thanks -
i have seem progs that can lock onto scrambled signals.
however, they are for pal only. -
go to babblefish.com u lazy asses. oh btw, i start a job with a cable company 2mar0 so hopefully i will learn how to "crack" the channels
With our ANALOGUE caputure cards you will only succeed in capturing (and cracking) ANALOGUE broadcasts. There are many ways which cable and satellite companies encrypt their channels. Firstly, you must find out which encryption technique your supplier uses. In Europe Nagravision and Cable Crypt are both popular.
If the encryption method uses vertical/horizontal sync adjustment (as mentioned earlier in the thread) then you can download utilities (such as ccd) which allow you to change the sync values and correct polarity of the incoming signal.
is it even possible cause all we get are wild goose chases,,,,
well ill check back here every now an dthen if it is possible plz say so and how if you knwo
Ati Radeon 3200 HD no overscan [SOLVED]
By carlos28355 in forum Media Center PC / MediaCentersReplies: 33Last Post: 9th Sep 2011, 11:38 -
ATI Radeon 4870 HDMI audio
By shorto in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 21:56 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 15:52 -
Visiontek ATI Radeon HD2400 Pro Help
By mattman1968 in forum ComputerReplies: 2Last Post: 11th Jan 2008, 13:13 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 16:25
