This is really a playing issue on my PC. I capture Hi-8 and VHS at 352x480 using VirtualDub on my Radeon 64 vivo, mjpeg set to 2 fields if > 240 lines.
My regular PC desktop shows full on the TV screen at 800x600, but playing through any application (e.g., Media Player) the image on the TV and monitor has black space above and below. I suspect there are not enough lines to fill the TV screen.
Would capturing at a higher horizontal resolution fix this? If so, what's a good resolution to try?
Live every day to the fullest as if it is your last, because someday it will be.
No, your TV-Out is adding overscan to the image. You will need to figure out how to turn off overscan if you want the image to truly fill the TV.
teddymines,
try and adjust the refresh rate for your video out.
under control panel, display, settings tab, advanced -
Thanks, I tried tweeking the monitor settings in the display control panel. In particular, I tried stretching and moving the monitor image, while watching the TV screen. It had limited effect during playback, and there is no underscan/overscan setting I can see.
Again, my desktop shows fully on the TV, so it must be either the application or the AVI I'm trying to view.
Just as a note, I have to do this with the monitor running at 800x600 @60Hz which is a 4:3 aspect ratio. My AVI is 352x240 which is 4:2.72. Could it be that my card is trying to keep the 4:3 aspect ratio by adding the requisite lines to the top and bottom?Live every day to the fullest as if it is your last, because someday it will be. -
Yep, get yourself zoom player or other flexable media player. Sasami 2k is in the DVD players section under SVCD ( don't know why ) seems to work well.
WMP only allows .avi's to be 1:1 ratio so it would screw it up.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 18:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43 -
(PC)Game screen not filling out the monitor
By Moontrash in forum ComputerReplies: 4Last Post: 28th Feb 2010, 21:52 -
full screen high def video playback program
By syeager in forum LinuxReplies: 4Last Post: 11th Jun 2008, 10:39 -
Full screen playback from firewire DV source
By schematic2 in forum Newbie / General discussionsReplies: 3Last Post: 11th Jan 2008, 01:19
